Page 1 of 3
2010 R/T Challenger lose HP with Predator
Posted: Sun Jun 13, 2010 1:19 pm
by mr.busa
RE: 2010 R/T Challenger lose HP with Predator
Posted: Sun Jun 13, 2010 2:58 pm
by bighemitex
any datalogs? if you are getting any knock it will pull power. also the not making power on a custom tune is the fault of the person custom tuning it, i would find someone else, i recommend hemifever or stu at inertia motorsports. when i install a tune in mine it doesnt seem to take hold instantly. it resets the computer after the tune installs so it seems like it takes around 200 miles for the tune to settle in and mature. there are people on here that would say it takes hold instantly but in my experience it takes a little bit. when i first put my tune on it runs kind of bad, but after a couple hundred miles it really pulls.
Posted: Sun Jun 13, 2010 3:00 pm
by bighemitex
but tomorrow when mikel sees this maybe he will provide greater insight. good luck to you.
Posted: Sun Jun 13, 2010 3:28 pm
by Mike_Levy
Was this tuned with the handheld or the CMR software? If they used the handheld, this isn't a professional anything
Posted: Sun Jun 13, 2010 3:46 pm
by mr.busa
he used software off of a computer. I fixed the high idel fault code by putting the factort programming back in.
Posted: Sun Jun 13, 2010 3:48 pm
by mr.busa
mr.busa wrote:he used software off of a computer. I fixed the high idel fault code by putting the factort programming back in.
Bad typing. I fixed the high idle fault code by putting the factory programming back in.
But I do want to add to this. Why did I lose horsepower and torque?
Posted: Sun Jun 13, 2010 3:54 pm
by bighemitex
no way to tell without logs and an experienced person to view them and interpret them
Posted: Sun Jun 13, 2010 4:09 pm
by Mike_Levy
The high Idle code was set due to the new TB. Because of the large blade it needs to be open less to keep the stock idle. When you put back the stock program is reset the adaptives.
The lost power is undoubtedly due to knock retard.
Posted: Sun Jun 13, 2010 4:18 pm
by mr.busa
The loss of power was prior to putting on the larger throttle body. The loss of power was after the programming was installed w/Diablo’s programming. Yes, he did all the updates/patches. Yes he did from software.
I put the stock throttle body on yesterday, reset the codes, and 0507 kicked back on. Reset the codes again, it kicked back on. Reset the codes, put the factory programming back in today, it hasn’t kicked back on.
You guys are completely failing to understand is I went to someone who is highly recommended by Diablo, who is sponsored by Vortech, AEM, Baer brakes and others. This is the reason why I did not do it.
You are also failing to understand is he spoke with Diablo……….
Posted: Sun Jun 13, 2010 4:40 pm
by mr.busa
Posted: Sun Jun 13, 2010 5:07 pm
by mr.busa
Posted: Sun Jun 13, 2010 5:16 pm
by HerDaytona
Can I ask what fuel, gasoline your are running in your Hemi??? This is important and can make dynos numbers come out lower than normal.
Re: RE: 2010 R/T Challenger lose HP with Predator
Posted: Sun Jun 13, 2010 5:21 pm
by bighemitex
edit
Posted: Sun Jun 13, 2010 5:22 pm
by mr.busa
Posted: Sun Jun 13, 2010 5:23 pm
by bighemitex
sorry dude i will edit that last post
