How do you select specific PIDs to show before datalogging?
My tuner wants certain pids in order to tune my vehicle but how do you select specific pids that will only show when i datalog instead of all of them?
RE: How do you select specific PIDs to show before dataloggi
what vehicle do you have? what model predator and what revision is it on?
its 03 dodge ram 5.7, the predator is U7137 with version 9r06. I want to log the stuff on my laptop when im doing some WOT runs, unless the handheld will let me record these parameters: RPM, Pratio, Long term fuel adaptives for both banks, short term knock retard, and engine coolant temp.
if you use your laptop and the dataviewer program, you can select whatever parameters you want...
it will give you a list of everything, and you check/select the ones you want to data log...
then click the Start Recording button to start logging those parameters that you selected...
ok thanks. hey what kind of driving do i need to do when i start recording? Should it be about 5 minutes of all WOTs or should i do some normal driving, stop n go traffic, and then some WOTs?
see what your tuner wants... he's the one that's going to need and be looking at the data...
