5.3L maggie charger question?
huskerblood
Post by huskerblood »
U7198 newest version
2001, Silverado, 5.3L
Does anyone know what settings to tweek to get the supercharger running well enough to drive? Have the m112 installed but I would like to be drivable until I can get to the dyno shop. i believe 42# green tips are standard with this kit.
orig.grg
(289.69 KiB) Downloaded 109 times
RE: 5.3L maggie charger question?
You NEED a custom tune to get it going...
huskerblood
Bummer, guess I'm walking for a bit
gump2388
Post by gump2388 »
that should have been a factor when ordering the kit?? should have known it had to go to the dyne with that much of a bolt on :) :punisher:
fernanbfg
Post by fernanbfg »
Isn't there a way to get the Magnacharger canned tune from the superchips handheld that comes with the kit? And then copy it onto your Predator?
fernanbfg
Post by fernanbfg »
Reinstall stock tune and then send the ECM to Magnachager and have them flash thier tune?
sickREDsierra
Post by sickREDsierra »
yeah i wouldnt drive it with 42 pounders in there, you will wash the cylinders man. bad news. until you have a tune with set parameters for those injectors, regardless of FI, dont drive it.
if you HAD to, you could install the charger and leave old injectors in, and putt it to the shop. change the bigger injectors when you get there. as long as you arent getting in any boost, the FI wont hurt anything. FI -- forced induction.
cool ? otherwise your PC is commanding a percentage of flow for the stock injector (29ish lbs) depending on year model... and that same % flow on the 42's will wash the cylinder :)
kisses
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
kisses -- HAHAHAHAHAA!!!!
you crack me up...
he's back!!!! well, for today anyway :lol:
sickREDsierra
just til 2.30
gotta be careful !!
