2006 VortecMax - Unknown Error()
Posted: Thu Jun 24, 2010 1:17 am
by sceptre
Hey guys, just picked up a U7192 9r11 for my 2006 Sierra VortecMax (1500 6.0L Auto).
I hooked it up and backed up my current setup perfectly but it would not load a new program. It would go 5% into it and stop with Unknown Error().
I have an ECM interface module for my alarm system, which I removed but it made no difference. The only other thing I can think of may be that I do not have the factory stereo system. I have an aftermarket CD player but do not have any ECM interface modules as I really dont like the chimes anyway.
Any information would be greatly appreciated.
Nick
RE: 2006 VortecMax - Unknown Error()
Posted: Thu Jun 24, 2010 9:58 am
Many times the harnesses used to connect aftermarket stereos will cause these types of issues.
Posted: Thu Jun 24, 2010 11:38 am
by sceptre
i have no fancy harness to connect to my stereo. I use a simple harness that allows me to use power and ground out of the factory harness. I use RCA's for running my amps and thats it. The only thing that I could see causing an issue would be the fact that I do not have the original stereo hooked up.
Posted: Thu Jun 24, 2010 11:41 am
Nay changes to the factory harness can be a problem, Id look into disconnecting the stereo.
Posted: Thu Jun 24, 2010 11:53 am
by sceptre
Can i just pull the fuse for it? Or should i put the original one back in?
Posted: Thu Jun 24, 2010 12:36 pm
Id rather you try disconnecting it.
It is the wiring on the bus that I am worried about.
Posted: Thu Jun 24, 2010 7:17 pm
by sceptre
this may be a dumb question...but under tool info my version is 9r11 but my hardware is unknown...is this normal?
Posted: Fri Jun 25, 2010 1:27 am
by sceptre
Took another try at it this evening....I did not pull the stereo as I didn't have time. I pulled the Radio, Radio Amp and Info fuses as well as hooked up a battery charger and tried agian. This time it went through and said "Unable to read vehicle type(1)" when it was trying to put new program onto truck.
Posted: Fri Jun 25, 2010 1:52 pm
by sceptre
okay....unhooked aftermarket CD player...no change. Any ideas?
Posted: Mon Jun 28, 2010 11:24 am
by sceptre
tried it again over the weekend with the deck out and it worked perfectly....not sure what I did the first time. Thanks a million for the info.
Posted: Mon Jun 28, 2010 11:43 am
Awesome.
Glad to hear it.
Posted: Wed Jun 30, 2010 11:26 am
by racer2896
did you ever figure out what the problem was cause i have the same problem and pulling my radio completely out doesnt help
