2004 Avalanche will not accept tune from U7193
crank
Post by crank »
I recently sent in my Predator U7193 to get it updated as I wanted to use it on a newer pickup and could not do the Internet downloads with it at that time. I got it back and attempted to upload the 87 octane performance tune. The first time I did this I also tried to modify a few different settings and while uploading it would get the original then it would start to upload the tune to the pickup and around 15% or so it stopped and said it was unable to upload do to an Unknown Error (). So the next time I tried to upload the 87 octane without modifying it and it did the same thing. Any Ideas?
RE: 2005 Avalanche will not accept tune from U7193
Any aftermarket electronics inthe truck?
crank
Post by crank »
AstroStart, & Sub Amp (Had this switched off). I do have OnStar and did not pull the fuse but I was in a large tin shed and the two attempts were on different days
crank
Post by crank »
Any suggestions?
JB666GL
Post by JB666GL »
I'm curious too... I have the same vehicle, same tuner, and same problem.
ANYTHING and EVERYTHING aftermarket has to be disabled/removed/fuse-pulled...
so the remote start, the sub/amp, and anything and everything else... etc etc
crank
Post by crank »
I unplugged the the astro start, pulled the fuse for the sub amp, and pulled the Radio, Info, and Radio Amp fuses on the pickup. Tried it twice with the same results as before. What now?
crank
Post by crank »
Does anyone have any advise? I would like to get this figured out some time soon.
crank
Post by crank »
I am guessing that I am SOL since I have not had any responses.
Is there an aftermarket radio wired up in the vehicle?
crank
Post by crank »
factory radio
rletzgus
Post by rletzgus »
My pcm got screwed because of a brake module for my trailer. Had to get the pcm reflashed. unplug everything. Then I saw some post about this after that that said after all this is unplugged, disconnect the battery for a while then try again. But check the posts for sure. I did a search in the forums for "pcm reflash" on the posts and saw this.
2001 GMC Sierra
4.8L
K&N FIPK Cold Induction
Headers
2.5" duals with Delta 50 Flowmaster
B&M tow shift kit on 4L60E
Predator U1798 ver 9r15
MSD Ignition MSC Multispark coils
