7186 Help Please
bigdawg04
7186 Help Please
Post by bigdawg04 »
Downloaded and installed --.DSDownloader_Installer_2the crom file .2.1.9.exe " , then the u7186_dmx_lly_lbz-9r10.crom (978k) Now when plugging into truck when it boots and I go to install tune all I get is the message "Your Calibration is not currently supported " and none of the tunes are there, 45 , 65 , 85 and 120 tunes are gone ???? Then states it will try to restore original backup and then get the message " It was already restored or never saved "Help please Have never had a problem but now it will not show any tunes at all and says it does not have the original backup. I have never never had a problem until this update Help Help Help
2007 Gmc Duramax Allison 2500HD 4 wd 4 Door
Blocked and Fingered
Predator u7186
S & B Cold Air Intake
Damon
bigdawg04
Post by bigdawg04 »
Well , had to put it back to Crom 9r08 and all is good, tunes are all back and loads perfect. Can you please let me know what to do to get the 9r10 to work, there is diffenetly something wrong when using with the 7186
Has anyone tried and been successful with the 9r10 crom ?
Predator u7186
Damon
The new update may not recognize some older calids.
If you load 9r10 and it says it does not recognize the vehicle, choose the modify stock tune option and let the tool save a copy of the backup file, upload it to the PC, then email it to [email protected] and we will make a new update for the tool with your calid supported.
bigdawg04
Post by bigdawg04 »
Wow, I have always been a 110 % supporter, but why would a crom be posted if it's known not to work with all the vehicles listed ? Should not have to go through all that, why was it posted if it will not work ?
Predator u7186
Damon
rydnhi4x4
Post by rydnhi4x4 »
What does the 9r10 update actually do for the LBZ motor?
http://www.thetruckstop.us
07 - CHEVY LBZ DURAMAX
All-Terrain T/A® KO - 295 75R16,
DYNOED ON 20 July 08 WITH -
PREDATOR SET ON THE 85HP TUNE / 423 RWHP - 709 FT/LBS
PREDATOR SET ON THE 120HP TUNE / 458 RWHP - 754 FT/LBS
Adds adjustable timing and fuel rail pressure settings.
rydnhi4x4
Post by rydnhi4x4 »
Cool thanks
bigdawg04
Post by bigdawg04 »
Mike sent information you requested yesterday, awaiting file to load as of 6/28/10
Predator u7186
Damon
bigdawg04 wrote:Mike sent information you requested yesterday, awaiting file to load as of 6/28/10
shooting for the end of the week.
bigdawg04
Post by bigdawg04 »
Nearing end of week, anything yet ?
Predator u7186
Damon
bigdawg04
Post by bigdawg04 »
End of week, anything yet ?
Predator u7186
Damon
Sorry, not yet.
You are running 9r08 currently, right?
bigdawg04
Post by bigdawg04 »
Yes , but sure would like to have the new adjustments !
Predator u7186
Damon
bigdawg04
Post by bigdawg04 »
mikel wrote:The new update may not recognize some older calids.
Still nothing ( sent requested info 6/29 ), 2007 Duramax, still do not understand why a crom was put out that was known not to work with all listed vehicles ? Have always been a 110% supporter here and have never had any problem with an update but this one kinda gets me.
Predator u7186
Damon
I can send you 9r08 to use until we add your cals to the new update.
