2007 charger r/t manual shift points and rev limiter
Posted: Mon Jun 28, 2010 12:31 am
by scott57rt
What are the mode1 and mode2 manual upshift definitions? What is the stock rev limiter setting for 07 r/t?[/list]
RE: 2007 charger r/t manual shift points and rev limiter
Posted: Mon Jun 28, 2010 10:08 am
They are 2 different ways of disabling the auto upshift setting.
I think the stock limiter is 6K on the 5.7
Posted: Mon Jun 28, 2010 11:18 am
by scott57rt
How will the manual shift operate under mode1 as compared to mode2? Will it behave differently depending on which mode I select? I'd like to disable it, but I'd like to know the definitions of each mode before I select a mode.
Posted: Tue Jun 29, 2010 5:28 pm
by scott57rt
I read somewhere else that I should just try both modes and see what works. Is that correct?
Posted: Tue Jun 29, 2010 5:46 pm
Yes.
Posted: Fri Jul 23, 2010 10:51 pm
by CountWilhelm
What is a rev limiter/how does it work...what is an upshift definition mode...under what condition/need for power should the latter be changed/altered...thanks!!
