error trying to load 9t08a tune into predator for 05 durango
So I am trying to get trans control on my 05 durango. I downloaded the 9t08a crom from page 20 of the "no more trans control" post. When I try to update my predator the downloader software says "Download Failed, Failure writing binary payload to tool" and the tool says "format failed". Any ideas? I tried renaming the file to the same format as the others with no luck. I have no problem going back to the 9r07a file.
RE: error trying to load 9t08a tune into predator for 05 dur
what do you mean renaming to same format as others?
when i download the file from the link in the post it is named "u7137_9t08a_export_757.crom". I tried it that way first. Then I renamed it to "u7137-9t08a.crom" so it matched the same format as the file from the support page (u7137-9r07a.crom ). It gave me the same error both times.
dont rename files....should be no need.
Can you try it on a different PC or with a different cable
I will and let you know. I see the new crom posted this morning. I have already written it to the tool with no problem.
