2001 Firebird - U7198 - 9r15 - WOT Datalogging
- Whitehawk489
How come i cant datalog WOT with the U7198?
2001 Formula Firehawk
RE: 2001 Firebird - U7198 - 9r15 - WOT Datalogging
whats keeping you from doing it???
- Whitehawk489
sorry im asking in the wrong place. i was refering to datalogredux. just wondering why wot isnt available with the u7198
because that class II predator tool does not log the AFR (equivalence ratio) parameter.... that's any class II predator tool, 7192, 7193 included - it's not just the 7198's...
you'd need to use a laptop and the dataviewer program to do a datalog, and then you'd have the AFR (equivalence ratio) parameter available to select via the dataviewer...
- Whitehawk489
Re: RE: 2001 Firebird - U7198 - 9r15 - WOT Datalogging
thanks for the help! are you saying i need the laptop in the car? ive already used the datalogging to help adjust my ltft's. im just looking to what else i can do with my tuner. attached is my last ltft log.06MonteSS wrote:you'd need to use a laptop and the dataviewer program to do a datalog, and then you'd have the AFR (equivalence ratio) parameter available to select via the dataviewer...
RE: Re: RE: 2001 Firebird - U7198 - 9r15 - WOT Datalogging
yes.. you would have to connect the predator to your OBD port in the car... then connect the laptop to the predator via the usb/serial cable... then use the dataviewer program on the laptop to select the parameters to log and do the logging...
