Problems loading custom tune into programmer for 07 stang gt
Posted: Wed Jul 11, 2007 1:34 am
by kimmer
Ok, I installed a couple custom tunes before, but now i'm getting an error
"Custom Tune write failed at offset. 0x40000, size 1024, count 1024, code 27."
I know the tunes are good, because one of them I had loaded previously with no problems....any ideas?
Re: Problems loading custom tune into programmer for 07 stan
Posted: Wed Jul 11, 2007 9:37 am
by kmac1
kimmer wrote:Ok, I installed a couple custom tunes before, but now i'm getting an error
Baud rate 115200
Compressed send checked
make sure you have a clean original file in the folder with your tunes and that it is labelled the 7digits of your calid .frg and nothing else.
If it gives you a base file warning when trying to load, then you need to select your original file in the next window that pops up.
Kevin@DiabloSport
