Won't start
Posted: Fri Jul 09, 2010 2:44 pm
M2000
1999 Damon ultrasport 36.5' motorhome
1998 CAT 3126 diesel
Installed puck and engine won't start. If I take out only the ICP wiring harness connectors and reinstall the originals it starts fine.
The wire colors match the instructions for the ICP and the MAP so I have in correctly. I have a CAT troubleshooting manual and it shows the ICP sensor also.
I am using the connectors on the end of the new wire harness for the ICP. Doesn't say inthe instructions which connectors go on which sensor. If you have more info on the 3126 please send that also.
If I can't get get this working do I return it to you or where I bought it (Throughbred Diesel).
