Page 1 of 2
9V11 is Junk Also
Posted: Fri Jul 09, 2010 6:22 pm
by bigdawg04
Well the 9V10 would not work and you sent me a 9t11a that would not work , so I also tried the 9V11 and it will not work. You even had me send you my stock tune to work with ! Trying the 9t11a and 9v11 get the following, Seemed like it was going to work, it saved original, the when going to write tume, picked modify and says "Paramiters not available for this
vehicle/ transmission combination (2) "What a joke this is getting to be
RE: 9V11 is Junk Also
Posted: Mon Jul 12, 2010 10:17 am
It will still install tunes for sure. It simply did not see your parameters there, simple fix on our end.
Posted: Mon Jul 12, 2010 10:41 am
by bigdawg04
NO, it will not install tunes on my end, I have tried several times. And why does the new one not see my parameters ? Thought that is why you sent it because it had been fixed to see our parameters ? Guess have 2 wait a couple more weeks and try again ?
Posted: Mon Jul 12, 2010 10:56 am
So, please tell me what happens when you try to install the tune, without adjusting any parameters.
Word for word please....
Posted: Mon Jul 12, 2010 10:57 am
by bigdawg04
Just emailed you the Original tune Again, as requested
Posted: Mon Jul 12, 2010 10:58 am
Thank you.
Posted: Mon Jul 12, 2010 11:01 am
by bigdawg04
My bad the tune will install without adjusting parameters, but what good is this, I could not even calibrate tire size, speed limiter , axil ratio or anything, little lone the new features. Why have a tune that can not be adjusted to the needs ?
Thats not the point, I assure you.
We will resolve this asap.
Posted: Mon Jul 12, 2010 11:03 am
by bigdawg04
K, will be checking daily
Re: RE: 9V11 is Junk Also
Posted: Tue Jul 13, 2010 5:01 pm
by bigdawg04
mikel wrote:It will still install tunes for sure. It simply did not see your parameters there, simple fix on our end.
Simple but nothing yet ?
Posted: Tue Jul 13, 2010 5:47 pm
bigdawg04 wrote:mikel wrote:It will still install tunes for sure. It simply did not see your parameters there, simple fix on our end.
RE: Re: RE: 9V11 is Junk Also
Posted: Tue Jul 13, 2010 7:36 pm
by bigdawg04
Mike , I appreciate it but this one does have all the new features listed and will write it to the truck, problem is after its done the truck will start and immediatly die. Tried it several times and tried writing it again several times , with the same results, truck starts and dies ? Don't know if it has anything at all to do with it but the tunes used to show 45,65,85 and 120, now with this one they show tow,60,80 and 120
Posted: Wed Jul 14, 2010 11:39 am
Hmmm...any chance you can write one of the tgunes to the truck, then export last written and send it to me?
Are you modifying the tune when it fails? Does it still stall if you do not modify the tune?
Posted: Wed Jul 14, 2010 4:56 pm
by bigdawg04
It will save original, then I go to 80hp and modify the Axle Ratio, tire size and speed limiter, it writes the tunes just fine and finishes. Unplugged, start truck and die tried several times writing the tune , same results. Have tried with both the 60 hp and 80 hp tune. Have not tried installing without modifying honestly that does me no good with a tune. But until this tune I have always had 45,65,85 and 120 , this tune has tow,60,80 and 120.
Posted: Wed Jul 14, 2010 5:09 pm
OK, we see what happened, will have a fix asap.
