Page 1 of 2
Revised Instructions: Predator Update
Posted: Mon Jul 12, 2010 5:19 pm
by j.mike@diablosport
Revision Update Instructions
(for Trinity, please see Trinity Update Instructions):
PREP:
NOTE: DSDownloader does not work with Belkin brand USB-serial cables
Purchase
http://www.diablosport.com, click Products, then Online Store
-buy part #U7778 for PCs that have USB ports, OR U7777 for PC’s that have a serial port
OR
from Radio Shack, Best Buy etc:
-USB to Serial cable OR a straight 9-pin Serial/Serial cable
and a
-12 v 1 amp power cable, 2.5 x 5.5 mm jack- center pin is positive
Download the Software:
Go to
http://www.diablosport.com, click Support, then Downloads, enter Vehicle Type or Predator Part number (U71##):
Tip: Make sure to download all files by right-clicking the link and selecting “save asâ€
RE: Revised Instructions: Predator Update
Posted: Sat Aug 28, 2010 11:44 am
by onebadsrt
Hello,
I tried to download this and I can't get it to. I keep getting an error message about access denied. I have the verision 2.2.1.4 Please advise me what to do. Thanks. Michael
Posted: Mon Aug 30, 2010 9:05 am
I'm not clear on what you're unable to download if you already have the DS Downloader 2.2.1.4. Do you mean the update crom file? At what point are you getting the 'Access Denied' message?
Posted: Tue Aug 31, 2010 8:41 pm
by onebadsrt
Its on my predator. When I went to the dealer the other day I put my original tune back on my Challenger. I was running a custom tune. When I got home I went to put the custom tune back on the car and the predator didn't have it saved on it anymore. I went to ds downloader and put the tunes back on the predator so I could put them on the car. They showed being saved on the predator, but when I hooked the predator to the car they were no where to be found. I plug in predator-agree-options-custom tunes-import custom tune. At this point it says that I must go to ds downloader, this option is not allowed, return to main menu. The wording that the predator uses is different, but the meaning is the same. It just won't list the custom tunes.
Re: RE: Revised Instructions: Predator Update
Posted: Wed Sep 01, 2010 11:01 am
onebadsrt wrote:Its on my predator. When I went to the dealer the other day I put my original tune back on my Challenger. I was running a custom tune. When I got home I went to put the custom tune back on the car and the predator didn't have it saved on it anymore.
Whenever you use a Trinity or Predator to restore the Original Backup to the vehicle, it will reset itself. This means it will unmarry itself from the vehicle's ECU and erase any custom tunes that are stored in its memory. They need to be saved on your computer's hard drive before you restore the Original Backup, and reloaded after the tool is re-married to the car.
You can reload them with these instructions:
https://www.diablosport.com/spages/supp ... m_Tune.pdf
or here:
http://www.diablosport.com/index.php?na ... ic&t=23072
RE: Re: RE: Revised Instructions: Predator Update
Posted: Tue Sep 28, 2010 10:14 am
by 01BLKSVT
Do the canned tunes stay on the predator? If you return it back to stock?
Re: RE: Re: RE: Revised Instructions: Predator Update
Posted: Sat Oct 02, 2010 4:43 am
by VA4MEDS
01BLKSVT wrote:Do the canned tunes stay on the predator? If you return it back to stock?
Yes
Question on order of things
Posted: Fri Dec 03, 2010 5:52 pm
by AceHigh
If I have not ever plugged the Predator in to my vehicle, would I be correct to update the Predators "crom" file (if the version shipped to me is not the most current) before restoring any "Original Backup" to my PCM, being that my vehicle is definately stock?
If the answer is yes, then I would effectively skip over step 1 in the PDF file of how to update the Predators "crom" file and go right to step 2- "power up your Predator and connect it to the PC, then download the most current 'crom' file (9r23 for the u7135 or more current) and save it to your Desktop folder."
Step 1 would only be if I have already installed any custom tune onto my PCM. Correct?
Thank you in advance.
can't downgrade?
Posted: Mon Feb 28, 2011 3:37 pm
by McNicol
my Preditor u-7137 says cant downgrade u7137 from 9r09 to 9r10
when i try to update it.
whats up with dat?
thanks
McNicol
RE: can
Posted: Mon Feb 28, 2011 4:09 pm
by dmelt53
Tried to upgrade Preditor u-7137 says can't downgrade from9r09 to 9r10. What to do?
RE: can
Posted: Mon Feb 28, 2011 4:15 pm
why are you trying to go backwards??
RE: can
Posted: Mon Feb 28, 2011 4:43 pm
by McNicol
i dont want to backwards..... i have 9r09 want to put 9r10 in....
RE: can
Posted: Wed Mar 16, 2011 8:08 pm
by briqueinc
mine too it is showing "can't downgrade u7137 from 9r09 to 9r10" solution please!
RE: can
Posted: Tue Mar 22, 2011 6:40 pm
by HemiJunky
I had HHP Performance do a head, cam, intake, exhaust, throttlebody, underdrive pulley. I don't think I have the factory tune anymore. My question is how to do data logging? Any suggestions or how to do it?
RE: can
Posted: Thu Jun 23, 2011 9:13 pm
by Tava
Just got my predator today and when I plug it in it says my vehicle's calibration is not supported and I need to downgrade it.. I have a new flash from the dealer as of last week. I have the predator with the most recent version 9r07 installed...It wants to downgrade my car one level to calibration 68054120AE. I currently have 68054120AF which is a new flash from dealership as of a couple weeks ago..
will Diablo be coming out with a new revision to make the predator recognize Dodge's new calibration??? I really want to use my new predator but don't feel I should have to downgrade to old Dodge calibration as my factory tune...
