Suggestion: "Official Fan Settings Sticky."
Posted: Thu Jul 15, 2010 6:34 pm
This is intended for Mike L. or someone else that is on the Diablosport tech department payroll.
There are a lot of threads, on a lot of forums, with a lot of opinions, about, "What should the Fans be set to?"
Then, there are cars that are stock, have 170* thermostats, have 180*'s, are race cars, are daily drivers, etc.
It would be great if the company that gave us the option to adjust those settings, would tell us what settings they suggest, all in one sticky.
Please create a sticky, or turn this into a sticky; and explain for us, with a lot of very clear information and rationale, "covering all the bases," the following. You could even lock the thread to future posts.
I know this may be a lot of work; but, it would be extremely valuable for all of us, and may cut down on a lot of threads posted by a lot of confused people.
The settings we can adjust are:
AC off, high MPH, high speed fan on temp
AC off, high MPH, low speed fan on temp
AC off, high MPH, medium speed fan on temp
AC off, low MPH, high speed fan on temp
AC off, low MPH, low speed fan on temp
AC off, low MPH, medium speed fan on temp
AC on, high speed fan on temp
AC on, medium speed fan on temp
AC on, low speed fan on temp
1. Please clarify, just to eliminate the confusion about this: The MPH settings are just that. They are tied to the MPH that the car is traveling, correct?
2. And aside from that, the fan itself has three different speed settings: Low, medium, and high, correct?
For all of the following, if the 6.1, 5.7, and V6 use different thermostats, or if you recommend different settings anyway, you may need to break each of these down by specific platform:
3. What are the factory fan settings? Please give us the individual numbers for the following. It would be great to know this so we have a point of reference. Again, if different cars or models use different thermostats, we would need the settings for each platform.
AC off, high MPH, high speed fan on temp =
AC off, high MPH, low speed fan on temp =
AC off, high MPH, medium speed fan on temp =
AC off, low MPH, high speed fan on temp =
AC off, low MPH, low speed fan on temp =
AC off, low MPH, medium speed fan on temp =
AC on, high speed fan on temp =
AC on, medium speed fan on temp =
AC on, low speed fan on temp =
4. If using a factory thermostat: What should we change the fan settings to? Please give us individual numbers that we should set the Predator to. Not "-10* across the board," unless that is true in all cases; that we should simply set every individual setting to "X* less than the factory setting" (now that we'll have the factory settings above, we can understand that).
5. What settings do you recommend if we install a 180* thermostat?
6. What settings do you recommend if we install a 170* thermostat?
7. Do you recommend any different settings (from above) if the car is a:
A. Weekend only cruiser?
B. Daily Driver in Florida (extreme upper temperatures)?
C. Daily Driver in Michigan (extreme lower temperatures)?
D. Race car?
8. And the icing-on-the-cake would be: If you told us all the fan settings that you already have programmed into the Predator for the 93 & 91 Octane tunes. Again, it would be a great point of reference for us.
I hope you see all the different "what if's" that we see posted on forums every day. To have the "official" "Diablosport recommended" settings all in one sticky, would help a lot of people. Then, they still have the option to set them wherever they want.
Thanks for considering this.
D. Race car?
