Need tune for 2010 Camaro SS LS3
Andreas_2SS_RS
I got the stock tune from my car, where do I e-mail it to get it tweaked?
I have Airaid cold air intake, would like the speed limiter removed and a tune for Shell V-power (99 octane RON)
RE: Need tune for 2010 Camaro SS LS3
which diablo tune did you install?? all you have is the CAI for mods??
http://www.dslogredux.com/DiabLew_Tune/
Andreas_2SS_RS
I have a U7194 and can't do anything with it, after I backup the stock tune it tells me to send it to Diablo Sport and call customer service. I live over seas and have a hard time finding the time to call so I figured I would try to get contact here since there are no e-mail adresses available for support.
I can't change anything with the Predator not even remove the speed limiter.
Hello Andreas,
Where do you live?
Maybe i can help you out a bit!
does it give you a calid not supported message?
Where do you live?
aaaaah... sounds like you have an unsupported calibration ID in that car....
get your ecm updated by the dealer to a newer calibration.....
also, post up that copy of your original backup tune file...
Andreas_2SS_RS
Re: RE: Need tune for 2010 Camaro SS LS3
Hmm thats bad news if that is the case, bought the car in Chicago and shipped it to Sweden where I live and can't expect any support from GM over here since the Camaro is not being sold in Europe.06MonteSS wrote:aaaaah... sounds like you have an unsupported calibration ID in that car....
- 637084637085.grg
- My stock tune
- (63.01 KiB) Downloaded 191 times
RE: Re: RE: Need tune for 2010 Camaro SS LS3
Well maybe your lucky and can diablo fetch you an update revision so that your car is supported.
But you can go to any Opel dealer or GM brand they have in sweden if they have an Gen Tech 2 odb2 device.
They can access the American website from GM and download any new updates for the camaro.
I've seen this done by dutch dealers
Andreas_2SS_RS
Re: RE: Re: RE: Need tune for 2010 Camaro SS LS3
The GM dealers in Sweden are really bad and hardly support cars that they have sold themselves and are required to service, I think I'd rather sell the predator and get the tuning done on a dyno than having to deal with GM Sweden, but I hope that Diablo can help meSolid wrote:Well maybe your lucky and can diablo fetch you an update revision so that your car is supported.
RE: Re: RE: Re: RE: Need tune for 2010 Camaro SS LS3
when did you buy the car??
it's a 2010, and not a 2011, right??
Andreas_2SS_RS
Re: RE: Re: RE: Re: RE: Need tune for 2010 Camaro SS LS3
Its a 2010, bought it in march but it was used from som guy who drove it 1000 miles and decided he didn't have room for it. Don't know when it was first sold.06MonteSS wrote:when did you buy the car ??
RE: Re: RE: Re: RE: Re: RE: Need tune for 2010 Camaro SS LS3
ok, cool...
what revision is on your predator?? when it powers up and is at the main menu, the revision number is at the top of the screen.. . should be a 9rXX number... what is it??
you probably have to update your 7194 predator to the latest revision - 9r16...
you can get it here: http://diablosport.com/index.php?module ... lay&pid=88
you also need to install the DSDownloader program to be able to update the predator...
and you did buy the PC Interface Kit, right? that's the power adapter and usb/serial cable so that you can connect the predator to your Windows PC in order to update it...
Sounds like an old revision, lets get it up to date on 9r16
Andreas_2SS_RS
It says 9r11 so I guess what you are saying is that is the problem?
So once I upgrade it, will it work right away or do I need to load it with a tune aswell?
Will upgrade it tomorrow and get back with the result.
Thanks.
Thanks.
yep, that's an old revision... need to update that to the new revision...
after you update it, it will be good to go.. you can use it right away on your car...
Andreas_2SS_RS
The upgrade did the thing! Thank you guys for your help.
One more question what is the difference between the 92 octane tune and the Diablo Tune? (other than you need to use 92)?
Do the Diablo Tune remove the speed limiter?
