Largest Tire size B4 Traction Control gets disabled?
tomp
Post by tomp »
Hi, what is the maximum tire size (for Hummer H2 using U7192) I can go to before traction Control gets disabled? Thanks!
RE: Largest Tire size B4 Traction Control gets disabled?
This can be different on each vehicle.
I have seen people go real big with no issues, but you would need to have gears to offset some of the difference.
tomp
Post by tomp »
How would I know it was disabled? WIll I get a DIC display message or DTC? Thanks
The TC and ABS lights will stay on if you have exceeded the range of adjustment.
There are no other issues associated with this, and many guys are driving around like that.
tomp
Post by tomp »
Ok, but just so you know - I am not looking at this as a bug, but rather looking at it as a feature.
Hummer H2 drivers such as myself have been looking for a way to disable it while offroading for a while. You see, when TC is activated it limits your RPMs. This means if you are trying to climb a muddy hill and there is wheel slippage, you wont have the power to make it up the hill!
Thanks so much for your help.
What I was really hoping for particular tire setting that would cause this issue, so when I go offroad the TC will be disabled? BTW, I don't care if the speedo works or errors are on the display when offroad;)
If you have a tire size setting, please let me know?
