Tune posted
Posted: Thu Jul 22, 2010 5:17 am
by HHB
Here is the tune that I read from my stock 02 Excursion 7.3. It should be the 60hp economy tune.
Would appreciate if you could add the option to adjust the speed limiter as discussed in the the previous tread (U7170 - Economy tune and adjusting speed limiter).
RE: Tune posted
Posted: Thu Jul 22, 2010 10:31 am
There should be an adjustable speed limiter setting in the tool already.
RE: Tune posted
Posted: Thu Jul 22, 2010 5:34 pm
by HHB
I have been looking through the menus, but cant find it anywhere. I have U7170 (v.7r19d). Do I need to update?
Re: RE: Tune posted
Posted: Fri Jul 23, 2010 7:16 am
by dsquared
HHB wrote:I have been looking through the menus, but cant find it anywhere. I have U7170 (v.7r19d). Do I need to update?
You will probably need the hardware upgrade, also. Do you know how old the Predator tool is? It may have the smaller memory which crashes when you try to update to the newer revision, which has the adjustable parameters.....
Posted: Sun Aug 08, 2010 5:28 am
by HHB
Mike,
would appreciate if you could help me with this one. In the previous thread where I posted the initial request you responded with:
"Lower it?
Not with the Predator, but we could write a custom tune to do it."
and
"No charge for the speed limiter tune, export a copy of your tune and post it here..."
Posted: Mon Aug 09, 2010 10:58 am
OK, where do you want it lowered to?
Posted: Mon Aug 09, 2010 12:51 pm
by HHB
56 mhp will work fine. Thanks for helping me out.
Posted: Mon Aug 09, 2010 12:56 pm
The factory setting will not go lower than 80 MPH, I set it to 8- mph in this tune.
Posted: Mon Aug 09, 2010 2:06 pm
by HHB
That was quick. Appreciate your help. Thanks
