Want More
mustangsn95snake
Want More
I have an 07 Ford 6.0 diesel! I have the predator currently on the 100 hp setting and I want more! I will give another post with the cali id. I want an all out race program it currently has a cold air and plans for a turbo back and better intercooler are coming! Thanks!
mustangsn95snake
RE: Want More
And I have that problem with 2290 too so if you could incorperate that into the program as well!
Re: RE: Want More
I would suggest on some fuel upgrades as well. p2290 is causes when commanded injector pressure kpa is greater than actual kpa supplied to the injector. There is also an amount of kpa error which allows the + or - the amount of error. Some cases both fuel filters need to be replaced and the truck tested again. But its an actual issue with commanded injector pressure which we can correct.mustangsn95snake wrote:And I have that problem with 2290 too so if you could incorporate that into the program as well!
Cole Stevens
mustangsn95snake
Re: RE: Want More
cole wrote:I would suggest on some fuel upgrades as well. p2290 is causes when commanded injector pressure kpa is greater than actual kpa supplied to the injector. There is also an amount of kpa error which allows the + or - the amount of error. Some cases both fuel filters need to be replaced and the truck tested again. But its an actual issue with commanded injector pressure which we can correct.mustangsn95snake wrote:And I have that problem with 2290 too so if you could incorporate that into the program as well!
mustangsn95snake
Re: RE: Want More
mustangsn95snake
RE: Re: RE: Want More
The truck is brand new theres only 4,500 miles on it I would not think it needs a fuel filter yet also what can I do to the fuel system to upgrade it!? My cali id is VXCF4S3 so can you get me the tune that fixes 2290 and give me the tune I originally asked for I talked to your rep and he said that you guys have an all out race program (150 hp) Thanks!
mustangsn95snake
Ok found the program VXCF4S3 figured out how to put it on the tuner went to put it in my truck and this came up: custom tune will not be used it does not match original tune for vehicle. tune for this vehicle is c9a871a6:7c1598d2 please help if there is something im doing wrong let me know! Thank you!
jackgf250hdsd
mustangsn95snake,
what's up? I got the same msg. I think you might have to restore original backup, its what i did and then put in the modified stock tune which i think is the custom 100hp tune.
we won't know until monday when cole is back in the office. I just got back from Orlando and i was avg. 21mpg highway, what kind of mpg are you getting??
2007 F-250 Harley Davidson 4x4 CC
Magnaflow 4" turbo back (cat delete) 5" tip,
Afe stage 2/with pro-gaurd 7/pre-filter,
acufab intake elbow, limo tint all around, 8" on windshield, zoodad mod,
100hp tune...
100hp tune...
jackgf250hdsd
hey snake,
forget my last msg. that was not it as far as the modified tune. i just reloaded the 100hp tune and works fine. have to wait for Cole on monday.
100hp tune...
100hp tune...
Please export a copy of your original backup to the PC first then also make sure you have the COMPRESS SEND button checked on DSDL software. Then send the custom tune to the predator. It will send properly and show up in the predator under custom tune menu.mustangsn95snake wrote:Ok found the program VXCF4S3 figured out how to put it on the tuner went to put it in my truck and this came up: custom tune will not be used it does not match original tune for vehicle. tune for this vehicle is c9a871a6:7c1598d2 please help if there is something im doing wrong let me know! Thank you!
Cole Stevens
mustangsn95snake
mustangsn95snake
