'06 LBZ/Allison won't start after tune install
GVWR
Post by GVWR »
Updated my U7186 to 9r11 before first use. Now no matter what tune I install, the truck turns over, but doesn't start. Back to original and it starts fine.
What gives?
It also tells me I can't modify anything (like tire size) with the engine/transmission combo I have selected.
Really? Isn't the Allison the most common tranny for the DMax?
Have I really done something that wrong today?
Please help!!!
bigdawg04
RE:
Post by bigdawg04 »
Get in touch with Mike. I had same problems and they got it worked out and Mike sent me a tune that will work.
2007 Gmc Duramax Allison 2500HD 4 wd 4 Door
Blocked and Fingered
Predator u7186
S & B Cold Air Intake
Damon
bigdawg04
RE:
Post by bigdawg04 »
Mike, need to get the 9r11 off of here. I'm sure many are using it and having the same problems as above and that I had. The 9t12e is and has been working great :)
Predator u7186
Damon
Re: '06 LBZ/Allison won't start after tune install
GVWR wrote:Updated my U7186 to 9r11 before first use. Now no matter what tune I install, the truck turns over, but doesn't start. Back to original and it starts fine.
What gives?
Please help!!!
9t12e sent.
restore the stock tune then update it.
GVWR
"Application is Missing or Corrupt"
Post by GVWR »
Mike,
I sent you an email outlining my latest issue.
Deerediesel
RE: "Application is Missing or Corrupt"
Post by Deerediesel »
Hi Mike. I am having very similar issues. I just went through the 9r12 deal on a customers 7186 tool. I finally got a 9r11 download in it, and it updated fine. I put in customers truck ('06 or '07) and now it starts right up and then dies. Will the 9t12e fix this? thanks for any help.
9r12 from the web should take care of it.
bes ure to restore the stock tune first.
