2007 ram 4.7
2007 ram 4.7
put the 87 tune on,modified the fuel and top speed limiter,the fuel worked but the truck still shuts down at the factory setting,also the 91 gas tune seamed to disapear from the programer when modifying the 87 tune?does the speed limiter setting work for the 87 tune?
RE: 2007 ram 4.7
The limiter settings should work for any tunes, can you write the tune then export a copy of the last tune written and post it here?
last tune
last tune,should be a little fuel enrichment and limiter set at 140,tried 155,190 also.
- PCM_05094420AJ_Perf_87oct_modified.zip
- (3.34 KiB) Downloaded 92 times
RE: last tune
OK. we see the issue, I'll send you a new tune today.
