NEWBE POWERSPORT M2020 2007 CAT C7 IN FREIGHLINER MOTORHOME
Posted: Thu Jul 29, 2010 9:26 pm
by MNICHOLS4
Anyone have any suggestions for installation and user adjustment? Is it necessary to run the adjustment pot all the way to the dash. I have a 40 foot motor home. Should you adjust on the fly or set it and leave it? The engine is a Cat C7 350 hp. How about results?, ideas on what I can expect. Anything to watch for so I don't damage the engine. Thanks in advance !
RE: NEWBE POWERSPORT M2020 2007 CAT C7 IN FREIGHLINER MOTOR
Posted: Fri Jul 30, 2010 8:21 am
You dont need to adjust on the fly, you could experiment with settings and then leave it where you like it best.
Posted: Sun Aug 01, 2010 8:48 pm
by MNICHOLS4
Mikel
There is a real lack of info for the use of the power puck, or I have not been able to locate it. What indicators will tell me it is working properly?
I just got the puck installed in the motorhome and I'm worried that the 2 sensor connections are identical and there is nothing in the instructions to tell you which goes to which motor sensor. The motor started and ran installed the puck so I assume this is a good indication I have the right connector on the right sensor. Can someone confirm this ?
