High-Flow cats which tune?
89-TTA
Post by 89-TTA »
Was just wondering which I should use I have a 300 SRT8 with high flow cats and a K&N drop in filter. 93 CAI or regular 93? Dont know if the cats require more fuel.
RE: High-Flow cats which tune?
Gotta go custom to turn off the rear O2 sensors. Otherwise she's gonna throw a code and check engine light. And ditch the drop in. Its useless. You'd be better off with one of the cheapo eBay intakes then just a drop in. The drop ins have the exact same surface area as stock. There is no advantage to it. Conicals have more surface area of a less restrictive media.
You need a custom tune. Its against EPA regulations so they had to remove that option from the tuner.
89-TTA
Post by 89-TTA »
I know the drop in does not require the cai tune, but I have heard the cats gain 9-15 hp on the dyno. This makes me think I need more fuel thus I was wondering if I should use the 93cai tune wich I believe adds more fuel. As far as the O2s I am currentlly using plug foulers that seem to keep me from getting codes. Thanks.
Yeah, use the CAI.
Charger250
Post by Charger250 »
Probably going to need to add more fuel than that, only a wideband O2 or ideally a custome CMR dyno based tune will properly tell you this.
