Adjustments to standard 93 tune?
89-TTA
Post by 89-TTA »
When you make adjustments to say the 93 tune such as fan settings,shift points,rev limmiter etc and you then reinstall the stock tune to take it to the dealer. Do you then have to change all those parrameters again when you reinstall the 93 tune or does it save all the changes you have made?
RE: Adjustments to standard 93 tune?
you have to make them again... when you restore original backup, the tool is unlocked and reset back to it's original state...
no settings or custom tunes are saved... you will need to re-apply the changes...
Taggert_LOA
Post by Taggert_LOA »
could you backup the modified tune onto a pc and then upload it back into the predator to install back into the car?
you could save it out to your pc....
after you restore original backup to the car... you would then have to reinstall one of the diablo tunes to the car - because you can't import a tune to the tool unless it has saved your original backup first... and then after you've installed one of the canned diablo tunes to the car and it saved the original backup, you could import that saved tune file as a custom tune into the tool... then install that custom tune to the car..
Return to “General Questions”
