C6 locked up
emiked
C6 locked up
Post by emiked »
Installed Diablo tune in the U7194 in '07 C6 vette, then went back in and modified the fan settings and COT settings.3/4 (78%) of the way thru writting the modified Diablo tune, the accessory "on" mode in the C6 timed out, shut off and ceased writing. Now the Predator will not write to the C6, the car won't start, orignal back up won't load. Car accessory "on" works, but does nothing if you try to start it; Predator says last tune failed to load, and when it trys again, progress bars sits at 0% for a few minutes then times out - OBDII code P0100 - failure to communicate with ECM/PCM; Predator "can't detect vehicle type - HELP!!!!
RE: C6 locked up
I'll leave my cell phone number up here for about the next 15-20 minutes.
Gimme a call with the tool powered up in the car.
emiked
Post by emiked »
HI Mike - sorry I missed this note earlier - really didn't expect such a quick reply! I had already buttoned everything up and gone out for dinner (I am on the east coast, Maryland) - any chance you would be available for that call sometime tommorow? I will check back in the morning - if you will be avaiable, let me know a time window - and let me know if it is PT or ET.
Any suggestions of what to try in the morning?
Thanks for your quick response - Mike
Sure, write the # down, cause I'd rather not leave it up here.
I'm on the east coast, try me at around 1:00 PM as I have a few things to do in the AM.
emiked
Post by emiked »
You da' man!
- got the number; I'll give you a call around 1PM ET
Thanks again,
Mike
