2005 Chevy Z71-ABS Light
ForceOne
Post by ForceOne »
Our shop purchased the U7193 for the 05 Chevy Z71 (Vin B)...truck lights up the ABS and says E-brake is on. And yes, we are using the newest tune [just updated by you folks].
Is this a known issue??? Do we need to look elsewhere for the problem??
Chris
RE: 2005 Chevy Z71-ABS Light
Stock tires and gears?
Did you make any other adjustments to the tune?
ForceOne
Post by ForceOne »
No changes to tune except tire size (rev per mile).
Stock engine 5.3 Ltr
Stock gears
Z71, 4X4
ForceOne
Post by ForceOne »
Vehicle is running Toyo Open Country M/T 37X13.5X20
...with a 12" lift
yeeaaahhhhh... . that size is most likely out of the allowable range of the abs system...
ForceOne
Post by ForceOne »
It should be within range...predator can adjust up to 40" tires.
That does not mean the PCM will be happy with what you tell it though.....
