Shifting question????
wildworks
Post by wildworks »
I just installed the predator in my 01 f250 7.3L set it to the 60hp economy mode. and i ran it out on the highway and it doesnt seem to shift in to OD the rpms run out at 2000+ at 70 mph. is to be expected??? before the tunner it ran under 2000 rpm
thanks for any input.
willie
RE: Shifting question????
Post by willie »
The predator tune should have not change the shifting strategy, i will suggest try another tune to see if it has the same results, and maybe contact our tech line at 561-908-0041 with your calibration ID, which is explain in the main manual how to extracted, so we trouble shoot the problem, keep in mind this tool has being out with the same tunes for over 3 years with good customer feed back
thank you :wink:
Return to “Predator Ford Gas”
