ATTN C6 Vette users!
Posted: Sun Jul 15, 2007 1:46 pm
It has come to my attention that the C6 has a 10 minute time out feature that turns the car off if left in accesory mode for more than 10 minutes.
Please keep this in mind any time you are planning to upload a tune, especially if you are going through and modifying parameters.
There are two things that you really NEVER want to do while a Predator is writing to the car:
1.Unpluging the Predator
2.Turning the car off
Either of these two errors will cause a no-start situation, requiring the PCM to be reflashed with a Tech-II.
RE: ATTN C6 Vette users!
Posted: Tue Jul 17, 2007 1:52 pm
Here is a method to avoid this situation, by putting the car into 'run' position:
Push and hold the bottom half of the switch in for 5 or 10 seconds and it will go from accessory mode to "run" but wont start.
Posted: Tue Jul 17, 2007 2:04 pm
by emiked
Hi Mike - small FYI/update - after I did a little more digging, I found out the the 10 minute time out is when you shut off the engine - you have about 10 minutes of continued accessory power or until you open one of the doors.
When you do a hard switch into accessory mode, the timeout is about 20 minutes - still risky if you are sitting ther fiddling with various parameters...20 minutes can go by before you know it!
Thanks.
Posted: Thu Jul 19, 2007 9:13 am
by emiked
One more caution - don't forget to turn your headlight switch from "Auto" to "off" - especially if you are working in a garage; the auto setting may turn on the headlights when you get into "run" mode with the above mentioned technique and you don't want this extra load while programming.
Posted: Tue Jun 30, 2009 6:25 am
by syswayne
What is the difference in a Sport Predator and just a Preadator
Posted: Tue Jun 30, 2009 8:19 am
there is no "sport" predator....
they're all "Diablosport" Predator's...
Posted: Thu Jan 21, 2010 10:03 am
by BFD1
Posted: Thu Jan 21, 2010 10:25 am
by BFD1
hello?
Posted: Thu Jan 21, 2010 1:30 pm
sir, I dont generally check these stickies for new posts, I did see your new thread, no sense in posting in a non constructivemanner though.
fear
Posted: Tue Mar 09, 2010 11:28 pm
by stevegoeschl
wow i just got my new u7194 read the small manual now iam really scared 300.00 +- predator vs. 62,000.00 vette
RE: fear
Posted: Wed Mar 10, 2010 12:45 am
no need to be worried/scared...
load the tune and enjoy!!
RE: fear
Posted: Wed Mar 10, 2010 9:49 am
by CANUCKPREDATOR
i'll tell you what, i'll take that 62,000 vette off your hands if your THAT concerned.
Re: RE: ATTN C6 Vette users!
Posted: Mon Nov 15, 2010 12:33 pm
by quimbo
mikel wrote:Here is a method to avoid this situation, by putting the car into 'run' position:
Thank Mikel how long should it take to upload diablo tune and download stock tune? How long will the car stay in this "run" mode?
