U7186 Aug update calibration issue
I have a 2009 Duramax and recently did the U7186 Aug10 update download and it screwed up my unit so that it no longer is working. I sent a backup file to the support email ID last week and was advised until Diablo does a correction update for the calibration issue I couldn't use the unit. Any idea how long it will be before this update is posted to get the 2009 Duramax software corrected for the U7186 unit?
RE: U7186 Aug update calibration issue
Should be ready Wednesday ideally.
As of 3 PM Thursday still no update for the correction? Any update on when to expect the correction?mikel wrote:Should be ready Wednesday ideally.
Thanks,
Good luck Glen , support here has really went down hill in a big way
2007 Gmc Duramax Allison 2500HD 4 wd 4 Door
Blocked and Fingered
Predator u7186
S & B Cold Air Intake
Damon
Predator u7186
Damon
who did you sent the file to?
I sent it to [email protected] as told by the Tech. I still have a copy of the email and file. Who do I need to resend it to?mikel wrote:who did you sent the file to?
please resend it to that address as I cant find the email.
Doing it now.
Re: RE: U7186 Aug update calibration issue
mikel wrote:please resend it to that address as I cant find the email.
Resent again. I just realized I used "s" in the email id, sport thus hopefully you receive it this time.
Please acknowledge receipt of the file.
Thanks, Glen Odom
RE: Re: RE: U7186 Aug update calibration issue
got it.
thanks.
thanks.
Now that I got r13 loaded the tool will not finalize a tune. Tried 3 times and once it does the stock backup and goes into load the tune it seems to be going through all the various processes then close to what you would think would be the final it comes up with a message "Tune not finalized". When you doe the "more info" it notes ECM : error unlock for reflash (-1)mikel wrote:got it.
thanks.
What is my problem now? Thanks, Glen Odom
After loading the r13 test version and having problems I am back waiting for another fix to get my tuner back up. One of the techs said he was emailing you to advise of the issue.glendodom wrote:Now that I got r13 loaded the tool will not finalize a tune. Tried 3 times and once it does the stock backup and goes into load the tune it seems to be going through all the various processes then close to what you would think would be the final it comes up with a message "Tune not finalized". When you doe the "more info" it notes ECM : error unlock for reflash (-1)mikel wrote:got it.
thanks.
What is the expected date you may can get me a fix for the U7186 ? Thanks,
Mikelglendodom wrote:After loading the r13 test version and having problems I am back waiting for another fix to get my tuner back up. One of the techs said he was emailing you to advise of the issue.glendodom wrote:Now that I got r13 loaded the tool will not finalize a tune. Tried 3 times and once it does the stock backup and goes into load the tune it seems to be going through all the various processes then close to what you would think would be the final it comes up with a message "Tune not finalized". When you doe the "more info" it notes ECM : error unlock for reflash (-1)mikel wrote:got it.
thanks.
Any update on expected date of fixing the U7186 update issue? I got a trailer tow coming up that I would liike to get my tune working to make.
Thanks, Glen Odom
