2005 chevy corvette predator u7191 not working
arctic
Post by arctic »
hi there,i hope you can help me. i go through the install steps,when i come to the part of install to hit agree,i get this message on the screen.
unable to read p/n of calibration file. I have tried this a couple times with same results.
please help
my car is a 2005 corvette, automatic,ls2 .my predator is a u7191
ver gm e40-9r03
RE: 2005 chevy corvette predator u7191 not working
you need to have your key turned on (but engine not running, don't start it up)...
and IIRC, the vettes, you have to put them in accessory mode or something...
arctic
Post by arctic »
hi..did that all it gives me now is ecm 12596660 not found in vehical database.....
I do the steps in order....still comes up the same Help please
yep, very old calibration in your pcm...
you need to get it updated by your dealer...
tell them you are experiencing a battery run-down condition with your car...
there is a GM service bulletin for vettes regarding that issue...
and once they update your pcm with the new GM programming calibration for that fix, it will be good to go and the predator will work fine for ya...
but yeah, the only way to fix that, is to get your old pcm calibration updated by your dealer to a newer one...
