Recommendations
Posted: Wed Aug 25, 2010 2:34 am
Sorry for all the questions, but I am new the programmer thing but thanks to all of you I am figuring it out and getting my truck dialed in. But I have a couple more:
I am thinking about putting in a 180 thermostat, since I am doing this do you all recommend stock plugs or should I change the heat range? Also I am currently running Autolite XP's, have not had any problems as I know there seems to be a lot of debate on if anything other then copper cores should be used. But I have been hearing good comments of other sites about NGK V-Powers, since all of you or most use the Diablo with engine mods I wanted to get your advise.
MSD Coils???? Better Then Stock Or The Same?
One More Question, I know my truck is having issues with COT at WOT. By lowering the thermostat from 203 to 180, the coolant system should take away more the waste heat, thus not as much waste heat through the exhaust system lowering the cat temp? Am I correct in this?
2006 Dodge Ram 1500 5.7L
* K&N Intake System
* Cat Back System
* BBK Throttle Body
* 91 Tune (No 93 In Cali)
Thanks Again For All You Help,
Josh
* K&N Intake System
* Cat Back System
* BBK Throttle Body
Josh
