Gear Change Question
I've got the Predator U7194 I'm using on my 2008 Chevy Silverado and I'm changing the gears next week. I've been told you can use the predator to change the gear ratio setting but I was unable to locate it on the predator. Is this possible and if so where is the gear setting. Thanks in advance for any help.
RE: Gear Change Question
This will require a custom tune.
Export your tunes and post them here and I'll set you up.
Hopefully I did this correct.
This is on a 2008 Chevy 4wd 5.3 currently running 3.73 gears and switching to 4.88 gears. Need a tune for the new gear ratio.
- PCM_617631617301 Original.grg
- Original
- (59.21 KiB) Downloaded 82 times
- PCM_617631617301_87_Octane_Tune_modified.grg
- (3.25 KiB) Downloaded 93 times
See how this one behaves.
- pcm_617631617301_87_octane_tune_modified_488.grg
- (49.73 KiB) Downloaded 81 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
Sweet, thanks for the feedback.
