06 gto will not start
DS just restored my pcm. I reinstalled it,hooked up battery, turned key on. To this point everything seemed fine. Turned key to start & nothing happens. Please help. P.S. could it be the key/fob not communicating? Also plugged in Trinity to do a diagnosis & U0101 unknown came up. Did some research & found it means lost communication with tcm(transmission control module). Cleared code still wont turn over. Anybody? Thanks!!!
RE: 06 gto will not start
Thats odd.
Try disconnecting the battery for a second then see if it cranks.
If not, it is likely the key/VATS, as the PCM is programmed for sure.
I disconnected the negative several times. I even unplugged pcm & reconnected with no luck. Is it possible a auto transmission was restored instead of 6speed?
I've got a new unprogramed key fob. Could I try programming that to the car?
It will require a tech 2.
Not real happy right now. Car never had an issue until I plugged in TRINITY. Who do talk to about a refund?
