Gear Swap 2010 camaro
macwest
Post by macwest »
I just recently swapped my gears to 4.10 I was told I need my EBCM needs to be tuned for the gear swap. I am new to tuners and not sure who do I need to email or what do I need to do. I just found out SCT tuners let me adjust it but I really dont want to have to return my diablo sport who can help out?
RE: Gear Swap 2010 camaro
Export a copy of the last tune written and original backup to your PCand email it or post it here.
macwest
Post by macwest »
Here are the files. I changed gears to 4.10. Also can I get speed limiter removed?
637084637085.grg
Original Tune
(63.01 KiB) Downloaded 173 times
637084637085_custom.grg
91 octane tune
(3.25 KiB) Downloaded 164 times
macwest
Post by macwest »
Not sure if it makes a difference but I updated the revision on the trinity tonight. If so here is the new tuen i just installed with a new original
PCM_637084637085.grg
Original tune
(63.38 KiB) Downloaded 181 times
PCM_637084637085_91_Octane_Tune.grg
91 Octane tune
(3.25 KiB) Downloaded 189 times
johan
Post by johan »
Give this one a shot....
pcm_637084637085_91_octane_tune_4_10.grg
(54.82 KiB) Downloaded 153 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
macwest
Post by macwest »
Did not work.. My speedometer is still off by just under 16%. Need to get this done because my EBCM is off until the gear ratio is set correctly.
johan
Post by johan »
did it even change? If so in what direction?
Diablosport INC
macwest
Post by macwest »
It was tought to say but if there was any change it was that the speed was closer to where i should be by 1-2% but that still means it is off by 14% instead of 16%. My big concern is the EBCM since it controls the stability control based on torque and a gear change i did would definently set it off.
johan
Post by johan »
I am just curious here, can you see if the speedo changes at all with this file.
pcm_637084637085_91_octane_tune_4_101.grg
(54.82 KiB) Downloaded 182 times
Diablosport INC
macwest
Post by macwest »
This new one looks good. Using my Magellion GPS speeds seem to line up. Also Speeds with rpms seem correct.
When the first one flashed the usual sensor warning that happen during flash never happened. With the new one during flash I received the lights after flash they went away.
BTW does this also have speed limit turned off?
Thank you
Good news.
macwest
Post by macwest »
Thank you once agian for a fast reply and fix. I really appreciate it.
Return to “Trinity GM Gas”
