when i install the predator tune or the 87 octane tune the truck runs like crap! it bogs like the timming is WAY off and you are pulling a 100,000lbs behind the truck. it will stay in first untill its at about 4K and then clearup and launch hard into 2nd. if i keep the RPM's up the truck runs fine. if they get below 3K it will bog down and the engine temps start to raise (too much fuel) and fall on its face. the tunes that came with this tuner are WAY OFF!
i am a full blown GM LSX engine guru (i have an LS1 in my jeep with my own EFI Live tune
i have a stock 8.1L, stock MAF, no CAI, tight hose clamps, the truck is in perfect mechinical shape.
do i have a bad tune from the u7193? seeing as how the ally is not supported with a handheld do i just set the trans to manual?
