2006 Duramax 2500HD - U7186 from 2006(not updated)
In order to correct speedometer - should I be using tire size or height (32 inches)? I just added cold air intake and 4" exhaust (no cat) , should I see better fuel mileage? With these changes should I update my predator or stay with the old?
RE: 2006 Duramax 2500HD - U7186 from 2006(not updated)
Either way is fine, they both do the same thing.
I haven't had much luck in adjusting the speedo with the predator. My speedometer is always slower that I'm actually going. Best I had it was 2mph then I put 17's on and it is back to 4-5 mph slow also if I get the speedo close to correct it sets off the ABS light.
2006 Silverado 2500HD ECSB LBZ 4" MBRP exhaust, Blockerplate and Fingerstick, U7186 Predator, Kennedy Booststick, Isspro EGT and Boost gauges, S&B Intake.
I changed my tire size to the measured inches and my speedo has changed from 3 mph over to around 1 over.
Mikel - can you answer both of the other questions I asked. Thanks
Id update the Predator for sure, it has some new features.
