Ford 6.4 no forward gears, just reverse after programming
a customer of mine downloaded a new program with his 7164 and there are no forward gears, just reverse now. "ECKS fatal error" comes up on the Predator. Can anybody help this guy get to work tomorrow.
- j.mike@diablosport
RE: Ford 6.4 no forward gears, just reverse after programmin
He called in and spoke with Vas and myself. The tuner was able to restore the vehicle back to stock 100%, and we've tried a battery reset so far with no luck. As we left it he's going to get it back to the dealership and we'll see what happens. I asked him to follow up and let me know whatever they find.
Diablosport Sales Team
Caffeine Engineer
Please do no PM me! Send an email to [email protected] if you need to contact me.
Caffeine Engineer
Same problem
I just updated mine and installed on my 08 f350 6.4 and im having the exact same problem!!!! Put the original back on and still no forward gear just reverse. Does anyone know how this all worked out for this guy!!! Not really sure what to do at this point. Called tech support and they had no answrs for me. Im really freaked out and hope this will not cost to much to fix!! Any suggestions would be appreciated. Ok so after talking with the tech support again today they told me to post the unit 1: 8u7a-14c204-cd and unit 2: 8c3a-14c337-ca As of right now getting it towed to the dealer and hope for the best!! Let you know the outcome!!! thanks Mike
So the ford dealer finaly got back to me today and the problem is the transmission control module needs to be replaced!!! I'm not sure if the predator caused this problem or what but not sure if I should try to program again when I get it back from the dealer. Any thoughts from anyone out there.By the way the part is covered under the factory warranty. thanks
I cant see why it would need to be replaced rather than simply reflashed, unless it had some sort of internal failure.
Send the oredator in to be checked out just to be sure.
fill out the rma request form on our website under support.
warranty.
- streetdiesel
I know the cause of this is a problem in programming the TCM, if the programmer mixes Job 1 and Job 2 TCM files the truck will only have reverse. This problem has occurred with different brand programmers or tuning devices which is where I've seen it. I believe you either have a partial programmed TCM or a Job 1 TCM file on a Job 2 or new 2008 truck. If the TCM was left completely blank you loose the gear position(neutral or park) and the truck won't turnover to start. Hope this helps Diablo find the issue.
Agreed, I see this issue when someone does not restore the stock tune prior to going to the dealership, then they manage to get the tool to restore an old cal to the truck over the new update.streetdiesel wrote:I know the cause of this is a problem in programming the TCM, if the programmer mixes Job 1 and Job 2 TCM files the truck will only have reverse. This problem has occurred with different brand programmers or tuning devices which is where I've seen it. I believe you either have a partial programmed TCM or a Job 1 TCM file on a Job 2 or new 2008 truck. If the TCM was left completely blank you loose the gear position(neutral or park) and the truck won't turnover to start. Hope this helps Diablo find the issue.
