Looking for a fuel pressure sensor to monitor with Trinity
mmperfdiesel
I am looking for a reasonably priced pressure sensor 0-20 or 0-30 psi to monitor diesel fuel pressure. I will connect and monitor it with the Trinity.
RE: Looking for a fuel pressure sensor to monitor with Trini
i dont think it will work like that, you can only monitor them if the vehicle was installed with pressure sensors from factory. otherwise the computer is not programmed for them
The Trinity has analog inputs, so you can monitor up to two different 0-5v analog sensors.
Here is a 150 psi sensor for $65. http://aeroforcetech.com/products_sensors_oil.html
