Tow/Haul mode
grahamce
Tow/Haul mode
Post by grahamce »
Does the Tow/Haul mode over-ride the tune when engaged, and if so, does it over-ride all aspects of the tune?
Is there a way to program the tow haul mode separately from the non tow/haul mode? i.e. Using the Tow/Haul feature for a 92 octane tune, and non tow/haul for an 87 octane tune.
2007 GMC Sierra 1500 4x4
5.3L, 4spd
RE: Tow/Haul mode
no... tow/haul mode just uses a different set of shifting parameters... everything else is still the same... so, you can't have two different octane tunes...
zrmindless
RE: Tow/Haul mode
Post by zrmindless »
Hi!
Newby, soon to purchase a trinity for a 2006 Yukon 5.3L 4x4.
The question above still begs the question, what does happen to the tow/haul mode after a tune is loaded? Can you modify both transmission parameters with the Trinity?
Thanks!
And lookin forward to it. If you have a heart, perhaps you could estimate the month that the Trinity for this engine family will be ready to sell? :)
CANUCKPREDATOR
RE: Tow/Haul mode
Post by CANUCKPREDATOR »
One program in the truck, tow/haul just changes the shifting parameters by a percentage from the installed tune. NO way to have two different settings.
RE: Tow/Haul mode
the Trinity does not support your 2006 truck at this point... no ETA as to when it will yet...
no, the tranny settings would not affect the tow/haul mode shifting parameters... those are already modified in the preset tunes, but if you make changes yourself with the programmer, it changes the normal mode/driving parameters...
both can modified if you get a custom tune tho... the diablo CMR custom tuner has access to everything in the tune file and can modify things individually...
