Predator Logs MAF in g/s how do i get a HZ value from this
trickpro
Post by trickpro »
like it says. im logging in grams/second and need Hertz
RE: Predator Logs MAF in g/s how do i get a HZ value from th
check the full parameter listing... there is a MAF PID that logs the Hz already...
go through 'em all and look for it.. it's in there...
trickpro
Post by trickpro »
i logged all and still dont see anything
U7198x v.9r17
probably need to open DV if it is not in the predator.
aaaah.... you have a 7198... didn't say that in the beginning... heh...
yeah, your older vehicle may not report that with just the predator then...
newer ones do....
try using a laptop and the Dataviewer program to log... you'll have a lot more parameters available to ya in the dataviewer app to log... especially once you choose to view the infrequently used PID's...
the predator's have a limited amount of space/memory, so they don't have the entire available PID's stored in them that you can log, so see if it's listed with the data viewer - the dataviewer uses the predator as a pass-through device to read your pcm directly, and can log whatever is in and reported by your pcm...
cuz I dunno if there is a direct conversion for grams per second to hertz man...
trickpro
Post by trickpro »
logged all and opened in dataviewer. selected show infrequently used PIDs still only see the g/s values.....so there isn't a way to covert it then?
k, so your pcm does not report it then...
I did a few searches online, and have not found any conversion for g/s to hz at all man...
