Need adjustment for New Gears
Brad519
Post by Brad519 »
U7194
v.9r18c
2008 Chevy Silverado
Stock gears were 3.73 swapped to 4.88 gears
need an adjustment for the new gears after the 9r18 update
PCM_617631617301.grg
Original
(59.36 KiB) Downloaded 80 times
PCM_617631617301_87_Octane_Tune_modified.grg
installed tune
(4.25 KiB) Downloaded 86 times
here you go:
pcm_617631617301_87_octane_tune_modified_488_001.grg
(49.83 KiB) Downloaded 75 times
(49.83 KiB) Downloaded 63 times
one will work, one will not....let me know ;)
Brad519
Post by Brad519 »
They both seem to work.
I've tried both and the speedo is right with both of them.
The 1st tune seemed to possibly have a little more torque to it but could just have been the difference in the update.
Is there something to check to determine which one I should run?
Nope, if they both work, its all good.
Brad519
Post by Brad519 »
Ok
And thanks so much for the help.
