So what does the puck do that predator doesnt?
07BigHornRam
Post by 07BigHornRam »
Im happy with my predator tunes only but what does adding puck do. i see the predator with puck tunes on my programmer. just wondering what this does.
ropnjessi
RE: So what does the puck do that predator doesnt?
Post by ropnjessi »
The Puc adds more fuel pressure adding to the Predator, things can get a little hotter but you will notice more power. I used to run the 2 together and had some fun with it...you really should have a EGT gauge.
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
07BigHornRam
ic ic i have a egt, trans temp, and boost guages. just asking did you mean rail pressure??
ropnjessi
Post by ropnjessi »
Yes
07BigHornRam
ok cuz i was wondering how the heck does it do that lol. so now is the cp3 still getting enough fuel cuz of this increase and does your fuel pressure drop to an dangerous level?
ropnjessi
Post by ropnjessi »
When running added pressure it is recommended to have the appropriate lift pump to supply the CP3. As far as how, I guess the Puc remaps the ECU in order to change the parameters.
07BigHornRam
naw i meant how does it raise fuel pressure. thanks for the info. hey quick question i notice you got a fass. was it a pain to install and did u notice a difference.
easy install.
it raises pressure by manipulating signals from the fuel sensor and PCM...
07BigHornRam
hey mike on average, how much psi does the puck drop in fuel pressure using stock lift pump.
ropnjessi
Re: RE: So what does the puck do that predator doesnt?
Post by ropnjessi »
07BigHornRam wrote:naw i meant how does it raise fuel pressure. thanks for the info. hey quick question i notice you got a fass. was it a pain to install and did u notice a difference.
It wasn't to bad to install, however just today it crapped out. Apparently I didn't get the warranty card submitted quick enough (30 days) so nothing is covered. Going to the FASS 150GPH Platinum now. Yes you will notice a difference. Before I installed an after market lift pump I could easily drain the rail, 0 pressure on the low side.
07BigHornRam
RE: Re: RE: So what does the puck do that predator doesnt?
damn sry to hear that man. u got some balls staying with that company after something like that. how long did u have it.
ropnjessi
Re: RE: Re: RE: So what does the puck do that predator doesn
Post by ropnjessi »
07BigHornRam wrote:damn sry to hear that man. u got some balls staying with that company after something like that. how long did u have it.
Well its a good pump just not the one I had I guess...lol. It was my own fault as far as not getting the warranty card in on time...
07megacab
RE: Re: RE: Re: RE: So what does the puck do that predator d
Post by 07megacab »
The amount your fuel pressure drops depends on your truck and the condition of the parts in your fuel system. The real concern is how much fuel pressure is ADDED to the rail. Stock, your already running 20k psi, give or take. I don't know how much the puc adds, but alot of chips, including mine, take it to the max pressure of around 26k psi, which is where the safety blowoff opens up. If you force this valve open too many times, it won't close back, causing a loss of pressure at all levels, and major drivability problems. I'm not trying to talk you out of buying a product from this company, because it is noticeably more power and alot of fun. You just need to be aware that, as with ANY performance enhancer, there are risks. Costly ones.
07BigHornRam
ic ic good info megacab. ropnjessi a liftpump may be in my future cuz not only for if i add power but also seeing the diagrams about water in the fuel doesnt look like a good thing to have lol. help me out here so what upgrades to the engine support higher rail pressure. 1 has to be the lift pump no one wants to drain the cp3 or the rail.
07BigHornRam
it would be nice if the makers of these products had the data (average) on a stock truck on how the pressures raise and fall other then just saying trans upgrades are needed. trans upgrades are needed when truck leaves the factory imo.
