the Trinity dosn't work on my HUMMER H2 2007 ??!!!
the_knight
Post by the_knight »
I purshased the trinity (T-1000 Serial: 6JT7F46)
and I've just received it to day.
Part: u7186 dmx_lly_lbz
version: v.1r07
form this website WWW.STREETSIDEAUTO.COM and regarding to them it fits with my application.
I tried to plug in the trinity to my car but after I reach this step when the trinity ask me to TURN the egnition ON and press continue, this message will show up _ UNABLE TO IDENTFY THIS VEHICLE_ I repeated this step many times ......
I checked the options menu to change the vehicle , I found MAZDA, MERCURY, GM, FORD, DODGE, CADILAC, CHEVROLET, CHRYSLER, JEEP AND LINCOLN.
Is there any update or Version could wark with car's engine (Gas V8 6.0L (Vortic) LQ4
I need your help ASAP.
Thank you in advanse.
Waseem
RE: the Trinity dosn
Part: u7186 dmx_lly_lbz ???? it's got a diesel vehicle selected???
did you go through Options - Change Vehicle type and select your correct vehicle first???
go change the vehicle type.. and go into GM....
hummers are GM vehicles...
I'd update the trinity to the latest revision first...
trinity_gm_can_gas-1r07a_update.crom on the update page:
http://diablosport.com/index.php?module ... ay&pid=153
imaninja
Post by imaninja »
lol, are you kidding me dude? you select a duramax and wonder why it wont work on your hummer? ...common sense...
johan
Post by johan »
Maybe he had a conversion Hummer, i have done a few of those, a duramax in those things is what it should came with from the factory :)
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
the_knight
1st of all thank you for your response and help, guys.
I downloaded Trinity Crom -> trinity_1r07.crom 32644k
then I downloaded Trinity Incremental Release ->10-29-2010->1r07a ->Trinity_gm_can_gas_1r07a update.crom 1212k
then I got this message Download Successful by Diablosport downloader and update tool complete and asked me to select option -> change vehicle type on Trinity to have CROM update applide , but when I checked this menu still my car it is not available on the list even under GMC list .
and I checked the show information from option menu , I found the old setting part: u7186 dmx_lly_lbz version: v.1r07 still same as before updating.
and additional to that I tried again on my car to plug in the trinity, after I reach this step when the trinity ask me to TURN the egnition ON and press continue, this message will show up _ UNABLE TO IDENTFY THIS VEHICLE_
what could I do now ?!!!!!
I was excited to try it on my car and feel the differnce after all my researches I did to find the best programmer on market and I compare many Brand name like HYPERTECH HYPERpac, EDGE programmer and JET modules programmer I chosed DIABLOSPORT so, please don't let feel disappointed.
I'm waiting for your help ASAP.
Waseem
jimb
Post by jimb »
To use the "gm_can_gas_1r07a" crom; Select any GM Gas 2011 vehicle. Trinity will reboot and will then use the new CROM.
the_knight
Re: RE: the Trinity dosn
jimb wrote:To use the "gm_can_gas_1r07a" crom; Select any GM Gas 2011 vehicle. Trinity will reboot and will then use the new CROM.
Thank you very much.
I will try your idea to day then I'll let you know if it's wark or not.
regards
the_knight
RE: Re: RE: the Trinity dosn
Hi, guys
I tried by chosing GMC 2011 from option menu -> change vehicle type on Trinity and that works successfuly.
so, now my trinity show that ( part: gm_can_gas version: v.1r07a ) but my car is not included in vehicle list (it is available only for Hummer H2 2008-2009 6.2 gas) and mine is Hummer H2 2007 6.0 gas.
and when I tried to plug in the trinty to my car -> I reach this step when the trinity ask me to TURN the egnition ON and press continue, this message show up_ UNABLE TO COMUNICATE WITH PCM_
WHAT should I do now ??!!!! WHAT must I try now??!!!
Thank you in advance and I'm waiting for a new ideas and your response guys.
johan
Post by johan »
Your Hummer is a 2007, correct?
Diablosport INC
the_knight
Re: RE: Re: RE: the Trinity dosn
johan wrote:Your Hummer is a 2007, correct?
:!: Yes, my car is Hummer H2 2007
:?: Does the trinity T-1000 support my car or not ??????!!!
:idea: Do you have any updated version that will help the trinity to comunicate with my car" PCM ?
johan
RE: Re: RE: Re: RE: the Trinity dosn
Post by johan »
Unfortunately it does not support the 2007 Hummer H2, it still uses the older communication protocol and is currently not supported in the Trinity.
Right now we do not have any ETA on when it will be supported as it is still in Alpha stages.
Diablosport INC
the_knight
Re: RE: Re: RE: Re: RE: the Trinity dosn
johan wrote:Unfortunately it does not support the 2007 Hummer H2, it still uses the older communication protocol and is currently not supported in the Trinity.
Thank you Mr.Johan
I appreciate your response and fast reply.
and really, I feel sad :cry: to know the trinity does not support my vehicle.
that means the trinty is useless to me and I paid 600$ for nothing, although I make sure this tool is fitting to my application through www-streetsideato.com (by live chat) befor I placed my order, add to that I confirmed by checking Amazon website.
I don't know what should I do :!: ????
Is there any solution to my case, Mr. Johan :oops: !!!!!
Regards
Waseem
johan
RE: Re: RE: Re: RE: Re: RE: the Trinity dosn
Post by johan »
Well like i said, we plan on supporting this application with the Trinity but right now we do not have a time frame when it will be done.
Diablosport INC
the_knight
Mr. Johan
Do you recommend to keep the trinity with me till you have ETA for my application ?!
or
should I replace the trinity with another tuner by diablosport ?!
and I would like to express my thanks for being patient with me.
j.mike@diablosport
Post by j.mike@diablosport »
Just FYI, if Johan doesn't know when you're vehicle is going to be supported, it may be a little while.
The U7192 is available now, though. Keep in mind the tunes (and horsepower ratings) are the same between a vehicle that is supported by both a Predator and a Trinity.
Diablosport Sales Team
Caffeine Engineer
Please do no PM me! Send an email to [email protected] if you need to contact me.
Return to “Trinity GM Gas”
