Can you use SD cards to load/save logs and tunes?
Posted: Wed Nov 03, 2010 10:35 pm
by hemiwagn
I'm new here, have a 2006 Dodge Magnum SRT8 and LC1.
i'm looking forward to logging PIDS with AFR.
I have not hooked up the Trinity yet.
Per the title above, can you use SD cards to tsf info to/from the trinity? I assumed so since there is a SD slot, but in reading the forums it seems that perhaps that funtionality is not yet supported.
RE: Can you use SD cards to load/save logs and tunes?
Posted: Thu Nov 04, 2010 12:50 am
by gizmodo
I know they enabled it for SRT4s, but I don't know if everyone else has it yet.
Posted: Thu Nov 04, 2010 9:05 am
by jimb
The most recent u7135 (support for SRT8) does not have it enabled. However, the next CROM will have it enabled allowing transfer of Dashboards and Tunes to/from SDCard. Also export of Logs to SDCard for playback with DataViewer. (Import logs into Trinity from SDCard was complicated and had little value).
Posted: Thu Nov 25, 2010 7:17 pm
by charala
Any rough idea on the release date for the new CROM? Thanks!
Posted: Sat Nov 27, 2010 6:23 pm
by zz50
Will this be available for Predators also? Which ones will be enabled?
Posted: Sat Nov 27, 2010 6:34 pm
by 06MonteSS
for predators, no, not at all... they don't have that functionality...
Posted: Mon Mar 07, 2011 12:22 pm
by Zoban
SD Slot works for Tunes, layouts and Logs now with the new crom..
Posted: Wed Mar 09, 2011 10:03 pm
by Nightshade
I am suspecting that it does not support SDHC Cards, I can't get it to see a 4Gb card I had kicking around.. no surprise there really, it's not an mp3 player.. Will see if I can find a small SD card tomorrow..
Posted: Wed Mar 09, 2011 10:20 pm
by Ill_Born_SS
works with 2gig SD. install and then power up.
just drag`n drop files into the sd card on your computer.
(DON`T PUT THEM IN FILES)
Posted: Mon Mar 14, 2011 4:57 pm
by MaxDiabloSport
Two things to keep in mind with the SD cards
1. Please use a 2GB or less SD card
2. Please insert the SD card PRIOR to powering up the Trinity. Inserting the SD card while the Trinity is powered up might cause some graphical issues. If this happens simply power cycle your Trinity.
