I have a U7194, v.9r16, for my 09 Vette. I have OBX headers and I have an Airaid installed. I have the Diablo tune in the car. I need to get a tune for codes p0036 and p0052. These are both for bank 1 pos 2 02 sensors. I believe I need to disable these 2 sensors.
Also the car is running very rich since I installed the Diablo tune. Could this be because of the altitude here? I am in Colorado Springs. I replaced the plugs today and the old ones are black. Attached are my base and current tunes. Also is there a way to adjust the shift points and line pressures with the Predator, I didn't see it on the menu. Thanks and God Bless
Steve
Tune for 09 Vette with LT and Airaid
Bradleywrench13
- PCM_628990629147.grg
- (60.06 KiB) Downloaded 110 times
- PCM_628990629147_Diablo_Tune_modified.grg
- (3.25 KiB) Downloaded 95 times
RE: Tune for 09 Vette with LT and Airaid
You'll want to contact Lew for a custom tune for theses mods.
no tcm/tranny support, so you can not adjust any tranny/shifting parameters...
for a custom tune for everything else, go getcha dialed in correctly and even more performance, check out http://www.diablewtune.com
