Dataviewer locks up U7193
Posted: Sat Nov 27, 2010 5:22 pm
by zz50
Dataviewer 3.3, Win 7, 9r11 crom.
When logging on a laptop the program locks up with no notice or reason. Reboot and it is OK again. Any ideas?
RE: Dataviewer locks up U7193
Posted: Sat Nov 27, 2010 5:42 pm
by jimb
After the lock-up and reboot; Before launching DV again, Post up the runtime.txt file found in "My Documents\DataViewer".
Posted: Sat Nov 27, 2010 6:01 pm
by zz50
Here you go... I believe this is the correct file.
Posted: Sat Nov 27, 2010 9:11 pm
by jimb
It's the correct file, but only shows opening an existing log file (Loading C:\Users\Paul\Documents\DataViewer\logs\test3.log).
Are you having issues opening a previous recorded log file? Or, logging using Predator attached to ECU?
Posted: Sun Nov 28, 2010 12:28 pm
by zz50
No issues with logging on the predator, everything works fine for the full length of the log. This particular log has no issues as I can see the whole thing until it stops. ???
Posted: Sun Nov 28, 2010 11:04 pm
by zz50
Try this one and see if this any better. I did not open anything after the shutdown. The log only ran a few minutes this time.
Posted: Mon Nov 29, 2010 8:15 pm
by zz50
Just a note I noticed today while trying to log before the file stopped. Worked well until I went to or just after WOT mode. Seems to me the other day the same result after WOT. Also I am using DV 3.3.0.7. Tried to load 3.3.0.5 but could not get a link. Thanks
Posted: Sat Dec 04, 2010 1:40 pm
by zz50
Here is another runtime log. I have since last time downloaded 3.3.0.7 since I noticed I was using 3.3.0.6. It worked OK for 2 days without freezing but today the gremlin has come back. Thanks for your help !!!
