2008 F350 superduty 6.4L diesel regen every drive cycle
bagger09
Post by bagger09 »
U7164 9r12a 2008 F350 super duty 6.4L
Regens every drive cycle giving code P2033
bagger09
RE: 2008 F350 superduty 6.4L diesel regen every drive cycle
Post by bagger09 »
I have 80 hp tune installed
Have you tried removing the tune to see if it still does it?
Thats an EGT code, maybe the EGT sensor is bad.
bagger09
Post by bagger09 »
Yes sir put stock tune back in it drove around for 50 miles problem did not come back. Can watch sensor on predator with 80 hp tune bank 2 jumps 1544 dgrees than back down to 544 as the right bank stays at 544.
I cant see anything in the tunes that could cause the EGT sensor to act up.
Please post up your calids.
bagger09
Post by bagger09 »
Ok drove 3 days with stock tune with no hick ups. Install 80 hp tune ran 2 days. Ran great first day even got uo to 18 mpg in city then engine light came on truck ran rough. codes unit 1 P2084 P20E3 P2033 first time this tune acted up codes were for unit 2.
calids unit 1 8U7A-14C204-FD unit 2 8C3A-14C337-CA Dealership finds nothing wrong with truck of coarse [because I am sure truck is still under warranty]
Odd. Unit 2 is the TCM, which would have nothing to do with the EGT.
Let me check into those codes.
