CMR Saving tune problem
bdrpm
Post by bdrpm »
I am creating a tune for a 03 cobra using the CAL files in the system. When i get everything done I am trying to save the file. I go to File- Save as and click it.... Nothing happens... any help? Should I be getting a pop up box to let me save it to a specific place? :!:
bdrpm
RE: CMR Saving tune problem
Post by bdrpm »
Never mind! set up new folder to save tunes to and it worked.
cool, let us know...
tandkperf
Post by tandkperf »
I'm having a simular problem. When I click Save As sometimes it opens a window so I can rename the tune, other times it does not. I assume it is saving anyway under the same name, but I do not want that. I wish to change the file name after centain changes. I am positive I am clicking Save As under the File menu. I have also noticed sometimes the file menu wiill show both save and save as but not always. I have also tried clicking "Ctrl A" but still getting the same results. I have also tried it with a table open and without a table open. It also doesn't matter if I have made changes or not.
Re: RE: CMR Saving tune problem
tandkperf wrote:I'm having a simular problem. When I click Save As sometimes it opens a window so I can rename the tune, other times it does not. I assume it is saving anyway under the same name, but I do not want that. I wish to change the file name after centain changes. I am positive I am clicking Save As under the File menu. I have also noticed sometimes the file menu wiill show both save and save as but not always. I have also tried clicking "Ctrl A" but still getting the same results. I have also tried it with a table open and without a table open. It also doesn't matter if I have made changes or not.
http://www.diablosport.com/index.php?na ... ic&t=31103
nemiro
RE: Re: RE: CMR Saving tune problem
Post by nemiro »
I am randomly having this issue, too. Only remedy I have found is to exit the software, and then try again, which of course loses all my changes. The above link no longer works, BTW.
__________________________
Neil Emiro - ND Performance
http://www.ndperformance.com
