PID's show but no data shown or recorded 7193
Posted: Sat Dec 11, 2010 8:00 pm
U7193 9r11, DW 3.3.0.7 Win7 x64 USB to serial to laptop. I used to have ECT, LTFT 1 and STFT1 but now I show the pid but no values or response and of course after saving the file they are missing. This along with the intermittent failure of the log freezing up. Here is the runtime data
Info: .\DataViewer.cpp, line 169, CDataViewerApp::InitInstance, DataViewer Version 3.3.0.7
16713978 Info: .\DataViewer.cpp, line 173, CDataViewerApp::InitInstance, The DataViewer is initializing.
16714212 Info: .\ParamTreeView.cpp, line 313, CParamTreeView::UpdateParamsFromLogData, Loading parameter tree from log file data.
16714695 Info: .\comm\httpconnect.cpp, line 208, CHTTPConnectThread::ExtractServerVersion, Server Version: 3307
16714695 Info: .\comm\httpconnect.cpp, line 194, CHTTPConnectThread::ExtractRunningVersion, Running Version: 3307
16714695 Info: .\comm\httpconnect.cpp, line 171, CHTTPConnectThread::Run, Exit HTTP Update Thread
16722168 Info: .\DataViewer.cpp, line 504, CDataViewerApp::DoPromptFileName, Opening log folder C:\Users\Paul\Documents\DataViewer\logs\
16741418 Info: .\DataViewerDocFileOps.cpp, line 86, CDataViewerDoc::OnOpenDocument, Loading C:\Users\Paul\Documents\DataViewer\logs\test17.log
16742510 Info: .\DataViewerDoc.cpp, line 761, CDataViewerDoc::OnUpdateToolInfo, u7193
16742510 Info: .\DataViewerDoc.cpp, line 827, CDataViewerDoc::OnUpdateVehicleInfo, ECU:GM P59 BUS:Class 2 VIN:2GTEC19T531240458 CALID:
16742510 Info: .\data\LiveDataBase.cpp, line 69, CLiveDataBase::SetUseBus, BUS:Class 2 m_eTransportBus:3
16742573 Info: .\data\PidRecordMgr.cpp, line 89, CPidRecordMgr::Load, Begin Load() of data for vehicle 2003.0 - GM - - - : CALID =
16742588 Info: .\data\PidRecordMgr.cpp, line 93, CPidRecordMgr::Load, Reading pid records, found: 909
16742620 Info: .\data\AnalogInput.cpp, line 55, CAnalogInputVector::ReadFromXml, NO analog_input tag found
16742620 Info: .\data\PidRecordMgr.cpp, line 89, CPidRecordMgr::Load, Begin Load() of data for vehicle 2003.0 - GM - - - : CALID =
16742651 Info: .\data\PidRecordMgr.cpp, line 93, CPidRecordMgr::Load, Reading pid records, found: 909
16743212 Info: .\ParamTreeView.cpp, line 313, CParamTreeView::UpdateParamsFromLogData, Loading parameter tree from log file data.
16743774 Info: .\ParamTreeView.cpp, line 313, CParamTreeView::UpdateParamsFromLogData, Loading parameter tree from log file data.
20669149 Info: .\DataViewerDocFileOps.cpp, line 1136, CDataViewerDoc::OpenLayoutFile, Loading Default_GM.dsh
21767131 Info: .\DataViewerDocFileOps.cpp, line 452, CDataViewerDoc::OnSaveDocument, Saving C:\Users\Paul\Documents\DataViewer\logs\test17.log
21767147 Info: .\DataViewerDoc.cpp, line 761, CDataViewerDoc::OnUpdateToolInfo, u7193
21767147 Info: .\data\AnalogInput.cpp, line 113, CAnalogInputVector::WriteAsXml, WriteAnalogInputVector 0 vector elements on object 0x26E398
