2005 300C Speed Control issues
Posted: Mon Dec 13, 2010 1:53 pm
I have a U7135 for my wifes '05 300C AWD. When I plugged it in the first time, it required that I flash the PCM with a calibration update, which I did. I then flashed it with the 91 octane canned tune. I changed the cooling fan settings, and firmed up the shifts.
Now, the speed control only works above 70 MPH. When you first start, you can turn the speed control on, and the light will illuminate. As soon as the car goes above 10 - 15 MPH, the light goes out, and cannot be turned back on until the car comes to a complete stop, or the car is over 70 MPH. Once the car goes below 70, the light goes out, and will not turn back on until you go over 70, or come to a complete stop.
I have returned to stock, but the problem is still there. I've downgraded the Predator to the 9R12 from the 9R27, still no luck. The speed control worked perfectly prior to this.
Thoughts?
Thoughts?
