2003 Dodge Cummins Map Sensor Problems
Posted: Mon Jan 22, 2007 2:44 pm
by 87hybrid
I just installed a new Power Puck that came with the Predator Stack kit. Vehicle is a 2003 Dodge Ram Cummins diesel. After I hook up the harness, I get a turbocharger boost sensor low code. I cleared the code, then tried it stock again and it was fine. I tried hooking up the puck again and it threw the code again. All the pins are pressed in the connector all the way, and all the wires are attatched. I tried reconnecting it a few more times with no luck. It doesn't seem to be a problem with the connection. Is it possible that there is a problem with the puck or the puck's harness?
Re: 2003 Dodge Cummins Map Sensor Problems
Posted: Mon Jan 22, 2007 3:47 pm
by cole
87hybrid wrote:I just installed a new Power Puck that came with the Predator Stack kit. Vehicle is a 2003 Dodge Ram Cummins diesel. After I hook up the harness, I get a turbocharger boost sensor low code. I cleared the code, then tried it stock again and it was fine. I tried hooking up the puck again and it threw the code again. All the pins are pressed in the connector all the way, and all the wires are attatched. I tried reconnecting it a few more times with no luck. It doesn't seem to be a problem with the connection. Is it possible that there is a problem with the puck or the puck's harness?
Please call 800.531.5484 and hit ext 1. There has to be something with the connection on that PUCK. We will give you a RMA # for you to send it in and get it fixed. You will be able to use the regular predator tunes for your Cummins truck in the mean time.
Thank you
Cole Stevens
